Pollutant Routing
Hi all!
I am using SWMM 5.0 in order to simulate TSS in stormwater.
I know that water quality routing within conduit assumes that the conduit behaves as a continuously stirred tank reactor (CSTR).
In reference to the substance involved in the reaction, a perfect and ideal mixing is assumed, and the universal law of material balance is applied:
where the coefficient K is the rate constant.
I would like to know if it is possible to modify directly K in the above mentioned formula. If yes, how?
I look forward to hearing from you soon.
Thank you,
Angela
  • You can modify it if you use a treatment equation.
