SWMM5.EXE
Could someone help me how to create SWMM5.EXE to run SWMM5 from DOS command? I downloaded source code from EPA site < Source code for the SWMM 5.0.022 computational engine> and followed the instruction given in readme.txt file under "makefiles\VC6_CON" directory.   When I give the command <nmake /f SWMM5-CON.MAK> it gives an error message:
'nmake' is not recognized as an internal, or external command, operable program or batch file.
  • Thanks Bob for your quick response. Yes, I was wondering about creating a new swmm5.exe from the source code.
  • Hello Krishna,
    There is already a swmm5.exe file when you download epa swmm5.  Is this request because you want to make a new and modified swmm5.exe?
