Hi!
Has somebody ever try to simulate a green roof with a bio-retention cell?
I can't understand exactly the meaning of some parameters, so if someone has an example on a real case of study, I will be happy to take a look!
thanks!!
Steve
You need to be a member of SWMM5 - Stormwater Management Model to add comments!
Join SWMM5 - Stormwater Management Model
  • Hello Steve,
    This is how the equation is used in the code
       getStorageOutflow(double depth)
       //  Input:   depth = depth of water in storage layer (ft)
       //  Output:  returns outflow from storage layer (ft/s)//
       //  Note:    drain eqn. is evaluated in user's units.
        double delta = depth - theLidProc->drain.offset;
        maxValue = delta * theLidProc->storage.voidFrac / Tstep;
        maxValue = feet  / second
        delta *= UCF(RAINDEPTH);    feet converted to mm
            outflow = theLidProc->drain.coeff *
                      pow(delta, theLidProc->drain.expon);
            outflow in mm = mm/hour * delta in mm ^ drain.expon
            outflow /= UCF(RAINFALL);   mm converted back to feet
            outflow = MIN(outflow, maxValue);  outflow
    to me the units are correct.
  • Segnalo ottima tesi Enrico Capuccini su uso di SWMM per applicazioni di tecnologie BMP ai sistemi di drenaggio, liberamente scaricabile
    http://amslaurea.unibo.it/2032/1/Capuccini_Enrico_Applicazione_di_t...
    Esemplificazioni e applicazioni a casi di studio
    • Thank you Nevio, that is a very good reference for urban LID's and BMP's!
      • Thank you!! I'm going to study what you gave me!
  • Hello Stefano,
    Here is a sample SWMM 5 LID model with Bio Retention - I hope this helps
    • Hi!
      In the Lid Control Editor for a Bio-Retention Cell there are two parameters who's phisical meaning I can't understand. They are the Drain Coefficient (C) and the Drain Exponent (n).
      According to the Lid Editor the  Drain Coefficient is [mm/hr], but according to the equation  C = 2D1/2/T (from the help) it seems to be [mm^0.5/hr].
      I don't understand what they phisically mean!
      Thank you!!
      Steve
