Infiltration trench parameters
Hello, I am modifying the LID controls from the text editor to perform a sensitivity analysis
What is the meaning of the fifth parameter assigned to infiltration trench surface layer and the fourth parameter to underdrain layer?
[LID_CONTROLS]
;; Type/Layer Parameters
IT-0.5%   IT
IT-0.5%   SURFACE   0            0          0.25       0.5      5
IT-0.5%   STORAGE   2000    0.67    40          0
IT-0.5%   DRAIN        0            0.5       0            6
Thank you.
  • Thanks, that was interesting about the canOverflow logic - it was something I missed viewing the code before.  I am adding a collage image of the LID possibilities
    3293138934?profile=RESIZE_1024x1024
  • The parameters for the Surface layer for LID modeling in SWMM 5 (the numbers are the column number on the input line):
    3293137694?profile=RESIZE_1024x1024
  • The parameters for the Underdrain layer for LID modeling in SWMM 5 (the numbers are the column number on the input line):
    3293138662?profile=original
    • Thank you very much, I found the following description on the executable file lid.c
      (https://github.com/OpenWaterAnalytics/swmm/blob/master/src/lid.c)
      Infiltration trench: the fifth parameter is designated as "canOverflow"
      and
      Underdrain: the fourth parameter represents the delay time
      But it is not specifically included in the LID CONTROL EDITOR. I am using the PCSWMM Model.
      Sorry for my English, thanks.
      Eugenia.
      //... for certain LID types, immediate overflow of excess surface water
      // occurs if either the surface roughness or slope is zero
      LidProcs[j].surface.canOverflow = TRUE;
      switch (LidProcs[j].lidType)
      case INFIL_TRENCH:
      case POROUS_PAVEMENT:
      case BIO_CELL:
      case RAIN_GARDEN:
      case GREEN_ROOF:
      if ( LidProcs[j].surface.alpha > 0.0 )
      LidProcs[j].surface.canOverflow = FALSE
      Underdrain:
      int readDrainData(int j, char* toks[], int ntoks)
      // Purpose: reads underdrain data for a LID process from line of input
      // data file
      // Input: j = LID process index
      // toks = array of string tokens
      // ntoks = number of tokens
      // Output: returns error code
      // Format of data is:
      // LID_ID DRAIN coeff expon offset delay
      • Thank you for reply , the fifth parameter is the  swale side slope.
        This is not available in the LID CONTROL editor. I must modify it in the text file, thanks.
        / Data Structures
        // LID Surface Layer
        typedef struct
        double thickness; // depression storage or berm ht. (ft)
        double voidFrac; // available fraction of storage volume
        double roughness; // surface Mannings n
        double surfSlope; // land surface slope (fraction)
        double sideSlope; // swale side slope (run/rise)
        double alpha; // slope/roughness term in Manning eqn.
        char canOverflow; // 1 if immediate outflow of excess water
        } TSurfaceLayer;
