open .out file
Hello everyone,
I would like to read the .out file in a text editor created after a simulation in SWMM5.
However I can't get anything readable when I open the file in notepad or some equivalent software. As I would like to combine SWMM and Matlab, I need to see and understand the structure of the .out file...
Anyone knows how to do that?
Thanks,
Nicolas
  • Hello Nicolas,
    Normally, if you are using MATLAB the SWMM 5 Console program is used (SWMM5.EXE) and a Time Series RPT file is made
    Subject:   How to use SWMM 5 DOS to make an Output Table in the RPT file
    You can make tables of the node,  link  and  Subcatchment output data in SWMM 5 if you use the DOS SWMM 5 program but not the Windows DLL.   Step 1 is to create the DOS batch file, Step 2 is to select the nodes, links and subcatchments, Step 3 is to run the batch file and Step 4 is to view the RPT tables or extract the data to Excel.  You can do this directly in the InfoSWMM and H2OMAP SWMM graphical user interfaces by using Run Manager, Step 5 to select the nodes, links and subcatchments and Step 6 to view the tables in the browser.
    Step 1.   Make a Batch File to call the DOS SWMM 5
    swmm5.exe Example1.inp  D:\swmm5.0.022\bob.rpt
    pause
    Step 2.  Add the nodes,  links and  subcatchments tables you want to generate in the RPT file
    CONTROLS         NO
    LINKS                 ALL
    NODES               ALL
    SUBCATCHMENTS ALL
    Step 3.  Run the Batch file
    Step 4.  Extract the Tables from the RPT File of SWMM 5
      <<< Node 17 >>>
                               Inflow  Flooding     Depth      Head       TSS      Lead
      Date        Time            CFS       CFS      feet      feet      MG/L      UG/L
      JAN-01-1998 01:00:00      0.000     0.000     0.000   980.000     0.000     0.000
      JAN-01-1998 02:00:00      5.910     0.000     0.608   980.608    26.065     5.213
      JAN-01-1998 03:00:00     11.935     0.000     0.887   980.887    22.826     4.565
      JAN-01-1998 04:00:00     18.291     0.000     1.143   981.143    21.176     4.235
      JAN-01-1998 05:00:00     12.640     0.000     0.916   980.916    22.426     4.485
      JAN-01-1998 06:00:00      3.925     0.000     0.493   980.493    27.578     5.516
      JAN-01-1998 07:00:00      0.388     0.000     0.161   980.161    38.134     7.627
      JAN-01-1998 08:00:00      0.067     0.000     0.071   980.071    26.937     5.387
      JAN-01-1998 09:00:00      0.029     0.000     0.048   980.048     1.878     0.376
    Step 5.  InfoSWMM and H2OMAP SWMM dialog for selecting nodes, links and subcatchments for generating a detailed RPT file table.
    Step 6.  Sample InfoSWMM and H2OMAP SWMM RPT Tables if Report Options is used.
    • Great,thanks!
      Cheers
  • Hi, The OUT file is binary.  It would better if you try to use the text RPT file.
    • Hello Robert,
      If I'm not mistaken, the .RPT file provides general statistics and variables of the model but not the calculated time series.
      As I'm interested in the order in which the elements are written in the .out file, it doesn't help me that much. Do you have any clues on how to anticipate the place of the time serie in the .out file?
      Thanks for your help,
      Nicolas
