Hello there,
I am trying to set a constant outflow concentration as the result for a treatment-equation, i.e. BOD: C=50.
Unfortunately, setting a constant value for the concentration does not work, the result of the effluent concentration would be just the same. However, I want the concentration to be exactly the value I selected in the treatment-expression. Moreover, it seems like every treament-expression with C=... leads to invalid results... What can I do to fix this? Defining an additional inflow at the correspondent node is not sufficient, as my flow should not change.
Furthermore, I am trying to implement an equation where a pollutant stands in the exponent of a equation, i.e. HRT^(0.75*TSS). With this expression, I would get an error when trying to simulate (invalid expression). Is it not possible to use this kind of expression? What else can I do to solve this issue?
Kind regards (from Germany)
Robert
  • UPDATE:
    I found out that (example):
    10^TSS
    can actually be replaced by following expression
    exp(TSS*log(10))
    Hope that helps anyone with the same problem.
    Cheers,
    Robert
  • No, that form does not work - it looks like you cannot have HRT raised to another pollutant exponent. I will check this
    This function does work, however
    R=0.01*COD*HRT^0.75
    • Thanks for the quick reply!
      I guess it's a very uncommon approach to raise a variable by a pollutant exponent, but maybe this could still be an option to be implemented in upcoming updates for SWMM.
      Anyway I will try to adopt to it by changing my expression.
      Kind Regards,
      Robert
