Re: parallel swmm and matlab
Hi
Ive been running an optimization of swmm using matlab. I was hoping to use the multistart and ga algorithms in parallel mode so I could make use of a multicore PC. I havent been able to get this running  (serial optimization is ok), since parallel calls are being made to SWMM and something is being overwritten..
What Ive tried is:
- rename SWMM5.exe in matlab folder to SWMM5_1,2,3 corresponding to the core no.
- assign the current .inp file to the current core number
- cycle through the core numbers as the optimization function calls SWMM
- Ive also renamed all the .m files which calculate the objective funcion to _1,2,3 etc
Ive noticed a .ini file in the matlab folder - does this also need to be modified?
Thanks
Dave
  • Hello everybody!, I have encountered the same issue in the last year, and because of this I have developed an open source solution to replicate the SWMM algorithm in Matlab, Python, and LabVIEW easily. I have called it MatSWMM an it is available at: https://github.com/water-systems/MatSWMM
    MatSWMM can be useful to model Real-time control for urban drainage systems, extract simulation results and edit systematically a system that has been created with the SWMM platform. I hope this can be useful to fullfil the requirements of the unpleasant batch simulation problems.
    Please check it out, and feel free to contact me (ga.riano949@uniandes.edu.co) if any doubt or suggestion appears.
  • I saw this link on LinkedIn for connecting EPANET to MATLAB, there may be some swmm5 tips you can glean from this experience
    https://github.com/KIOS-Research/EPANET-Matlab-Class
    the LinkedIn discussion was
    How can I linked MATLAB to EPANET?
    • Ive found a workaround for the moment, which is simply to open multiple sessions of Matlab until I have time for a proper fix! But thanks for the links
  • No, but this looks promising......thanks Bob
  • Have you tried setting the affinity of each one of your SWMM5.EXE to one CPU?  I can see how this is done in Windows Task Manager
    http://www.techrepublic.com/blog/windows-and-office/change-the-proc...
    the above link has has more detail including this good time saving tip
    "Now if you find that running an application on a specific CPU core works well, you might want to use it again in the future. If so, chances are that you won't want to have to go through the Task Manager each time. Fortunately you can create a shortcut to launch an application with a specific affinity setting.
    For example, to launch Disk Defragmenter so that it runs only on CPU 0, you would create a shortcut with the following command line:
    C:\Windows\System32\cmd.exe /C start /affinity 1 dfrgui.exe
    To launch Disk Defragmenter on CPU 1, you would create a shortcut with the following command line:
    C:\Windows\System32\cmd.exe /C start /affinity 2 dfrgui.exe
    The number that follows the start /affinity command is called the affinity mask and is defined as a hexadecimal number. However, the CPU core number can be calculated more easily using binary numbers. For instance, the command
    C:\Windows\System32\cmd.exe /C start /affinity 3 dfrgui.exe
    will launch Disk Defragmenter on both CPU 0 and CPU 1. If you convert 3 into a binary number you will get 0011. Under the affinity mask system, processors are numbered from the right to left beginning with 0 and since there are 1's in the first two places, this indicates CPU 0 and CPU 1.
    Suppose you have a Quad core processor. If so and you use an affinity mask of 4, that will convert into binary 0100, which indicates CPU 2. If you use an affinity mask of 9, that will convert into binary 1001, which indicates CPU 0 and CPU 3.
    For more information on the start /affinity command, open a Command Prompt window and type the command
    start /?"
    Good luck in your modeling!
