results table export
Is there a way of quickly exporting a timeseries of results from all nodes in a project? Using the report > table option requires the user to select each node one at a time, for instance, with a maximum of 6 nodes per table. I have over 150 nodes so am looking for a quicker way to select and export all ???
  • If you use the SWMM 5 DOS Engine and the REPORT function with NODES ALL then you will get a text output file with all of the node data.  You can see an example at the bottom of this page.
     CONTROLS NO
     NODES ALL
     LINKS ALL
    ?ui=2&ik=60d08093d9&view=att&th=1203fd54c64da8fa&attid=0.1&disp=emb&zw
    ?ui=2&ik=60d08093d9&view=att&th=1203fd54c64da8fa&attid=0.2&disp=emb&zw
  • wow, thanks for all your responses that was really helpful!
