Hello,
I'm working on the coupling of  SWMM with a homemade 2D superficial flow model. The later is written in Python.
For this purpose, I'm currently writing a Python wrapper for SWMM using ctypes. So far I managed to control a simulation from Python using swmm_step() and get results at each time-step using node_getResults().
But for my purpose I will need to exchange nodes data at runtime. Simply put, at each time-step I need to read values from given nodes, and then update them before the next time-step.
From what I've read in this forum about Matlab-SWMM interface, a proposed solution would be to run a full SWMM simulation between two "exchange time", read output files, update input files and run a new simulation. However I'm afraid this solution would introduce a severe overhead with file reading and writing.
So I'd like to know from people who have good knowledge of SWMM source code, if there is a safe way to change some node data during a simulation.
Thanks for your help.
  • I am looking to try the same thing with a FREE and OPEN SOURCE model called ANUGA. It is developed by researchers at the Australian National University  and Geoscience Australia https://en.wikipedia.org/wiki/ANUGA_Hydro#ANUGA https://anuga.anu.edu.au/ https://github.com/GeoscienceAustralia/anuga_core
    Yes any tips would be much appreciated....
  • Hello everybody!, I have encountered the same issue in the last year, and because of this I have developed an open source solution to replicate the SWMM algorithm in Matlab, Python, and LabVIEW easily. I have called it MatSWMM an it is available at: https://github.com/water-systems/MatSWMM
    MatSWMM can be useful to model Real-time control for urban drainage systems, extract simulation results and edit systematically a system that has been created with the SWMM platform. I hope this can be useful to fullfil the requirements of the unpleasant batch simulation problems.
    Please check it out, and feel free to contact me (ga.riano949@uniandes.edu.co) if any doubt or suggestion appears.
