The total precipitation in inches reported in the EPA SWMM Status Report (9.075-in) does not match the sum of precipitation data in my input file (15-minute time steps).  The starting and ending dates match, and continuity error is < 1%.  Any ideas about what could be wrong?
Thanks, Laura
  • I made a units mistake (how emabarrassing).  The sum of the 15-min precipitation input (inch/hour) needed to be devided by four.
    Thanks for your help.
  • Here is the one Subcatchment Model
  • Hi,
    Here is a small mode that uses your rainfall.   I have checked the values in Excel and they add up to the same values as SWMM 5.  You have 1+ year of rainfall, 15 minute intervals and intensity.
    3293150807?profile=RESIZE_1024x1024
  • Precip Data is attached.  I got the data from King County, WA as a .csv file.  I modified it to put data in the correct columns and then saved as a tab delimited .txt file for SWMM to read.
  • Do you have a copy of the precipitation data?
    Normally, i would say that the length of simulation is less than the rainfall record or there is missing data with a flag in your rainfall data.
