Example Groundwater Model in SWMM 5
Subject:   Example Groundwater Model in SWMM 5
The attached model shows three ways in which the groundwater model of the SWMM 5 subcatchments interact with the node depths of the hydraulic network.  The hydraulic network interaction can be either:
1.       At a fixed water surface elevation,
2.       At a time varying water surface elevation based on the inflow and geometry of the node and
3.       At a threshold node water surface elevation.
GW_INTERACTION.inp Download this file
