Exponential Washoff
Hi,
I wondering to understand the equation of "Exponential  Washoff".
W=C1*q^C2*B
where C 1  = washoff coefficient, C 2  = washoff exponent, q = runoff rate per unit area ( mm/hour), and B = pollutant buildup in mass units (User's Manual Version 5.0)
The washoff (W) is express in term of mass/hour. So there is a problem with the unit. I have a "mm" remaining in this equation to express the W in terms of mass/hour.
Maybe the term C1 is express in mm-1, but I can't find the information.
Thanks for helping me,
Amélie
  • Thanks for ansewring me. That helps! Have a great summer!
    amélie
  • // --- convert runoff to inches/hr (or mm/hr) and
    // convert buildup from lbs (or kg) to concen. mass units
    runoff = runoff * UCF(RAINFALL);
    buildup /= Pollut[p].mcf;
    // --- evaluate washoff eqn.
    washoff = coeff * pow(runoff, expon) * buildup;
    runoff is in units of inches/hour and buildup is in units of pounds
    the coeff and buildup are the same as you entered them except coeff is divided by 3600
  • 1st remember the internal units of SWMM 5 are old fashioned American Units so please excuse the mess of conversion - the load is utimately converted to kg even though it is computed as pounds
    2nd Each landuse on a Subcatchment generates a load in units of mass/sec
    // --- get local washoff mass flow from each landuse and add to total
    for (i = 0; i < Nobjects[LANDUSE]; i++)
    if ( Subcatch[j].landFactor[i].fraction == 0.0 ) continue;
    landuse_getWashoff(i, area, Subcatch[j].landFactor, runoff, tStep,
    WashoffLoad);
    3rd That mass/sec is converted to mass/ft3 by the runoff
    // --- convert from mass/sec to mass/ft3
    runoff *= area;
    for (p = 0; p < Nobjects[POLLUT]; p++) washoffQual[p] /= runoff;
