Subject:   How Does Green Ampt Cumulative Event Infiltration work in SWMM 5?
This graph shows the values of the internal SWMM 5 parameters for Green Ampt Infiltration for the pervious area of a Subcatchment during a simulation.  The parameters are:
·         F or FTOT which is the cumulative event infiltration at the start of a time interval in the internal units of feet in SWMM 5,
·         FU or current moisture content of the upper zone of the of the soil
·         FUMAX which is the saturated moisture content of the upper zone in feet and stays constant during the simulation
Figure 1.  How FTOT, FU and F change over time
Figure 2.  A closer look at how FTOT or F and FU Change over time in a Green Ampt Pervious Area Simulation.
  • Subject:   How Does Green Ampt Initial Moisture Defiict Work in SWMM 5?
    ·         Soil Moisture = IMD Max – (FUMax – FU)/Upper Soil Zone Depth
    ·         FUMax which is the saturated moisture content of the upper zone in feet and stays constant during the simulation
    ·         IMD Max is the user defined Initial soil moisture deficit and is a fraction
    Figure 1.  How Soil Moisture changes over time.
    Figure 2.  Soil Moisture and IMD are related – the Soil Moisture has a maximum of IMDMax.
