InfoSewer Inflow Control for a PUMP
You can control the pumps in InfoSewer and H2OMap Sewer by using a Pump Control which will control the pump based on:
1. Volume
2. Level
3. Discharge
4. Inflow
5. Time
If you use a By Inflow control the pump speed of the pump is increased or decreased to make the Upstream Wet Well Level Constant (Figure 1).
InfoSewer Inflow Control for a Pump with a Pump Curve
1. Volume
2. Level
3. Discharge
4. Inflow
5. Time
If you use a By Inflow control the pump speed of the pump is increased or decreased to make the Upstream Wet Well Level Constant (Figure 1) for an exponential 3 point curve
InfoSewer By Discharge Control for a PUMP
1. Volume
2. Level
3. Discharge
4. Inflow
5. Time
If you use a By Discharge control the pump speed of the pump is increased or decreased to pump the incoming Wet Well flow based on the pump rules and the geometry of the Wet Well (Figure 1).
