Perpetual Ocean
Using a computational model called Estimating the Circulation and Climate of the Ocean, Phase II (ECCO2), the NASA Goddard Space Flight Center Scientific Visualization Studio (I think NASA has a thing for long names.) visualizes surface currents around the world. This is beautiful science here. Make sure you turn on high-def and go full screen.
[via @aaronkoblin]
High-resolution maps of science
While we're on the topic of academic papers and how they're linked, Johan Bollen et. al used clickstream data to draw detailed maps of science, from the point of view of those actually reading the papers. That is, instead of relying on citations, they used log data on how readers request papers, in the form of a billion user interactions on various web portals.
Cross-fertilization. Saucy.
Each circle represents a journal and edges represent connections between journals, according to Johan Bollen et. al's clickstream model. Circles are color-coded by journal classifications from the Getty Research Institute's Art and Architecture Thesaurus.
So you have most of the engineering and physical sciences on the perimeter, medical-related areas to the left, and liberal arts is that middle cluster. Statistics is towards the top left, mixed in with demographics, philosophy, and sociology. There aren't many surprises in the clusters, but there are interesting, albeit weaker, links in the open spaces, such as religion and chemistry or music and ecology.
[PLoS ONE | Thanks, @drewconway]
Global forest heights mapped in detail by NASA
NASA has mapped the world's forest heights, based on satellite data, for a first-of-its-kind global view. While there are plenty of maps that show forest height regionally and locally, this is the first time it's been mapped globally with a single, uniform method.
These heights range from 0 to 70 meters. The darker the green the higher the tree canopies.
NASA believes the new map could help scientists with a new perspective on how much carbon forests store and more insight on carbon cycles within ecosystems.
Click through to NASA for the high-res version.
