This is a complete working example
[TITLE]
;;Project Title/Notes
BOD5 linked to Temperature
[OPTIONS]
;;Option Value
FLOW_UNITS CMS
INFILTRATION CURVE_NUMBER
FLOW_ROUTING DYNWAVE
LINK_OFFSETS DEPTH
MIN_SLOPE 0
ALLOW_PONDING YES
SKIP_STEADY_STATE NO
START_DATE 01/01/1988
START_TIME 00:00:00
REPORT_START_DATE 01/01/1988
REPORT_START_TIME 00:00:00
END_DATE 01/01/1988
END_TIME 06:00:00
SWEEP_START 01/01
SWEEP_END 12/31
DRY_DAYS 0.000000
REPORT_STEP 00:05:00
WET_STEP 00:15:00
DRY_STEP 01:00:00
ROUTING_STEP 0:00:05
INERTIAL_DAMPING NONE
NORMAL_FLOW_LIMITED BOTH
FORCE_MAIN_EQUATION H-W
VARIABLE_STEP 0.75
LENGTHENING_STEP 5
MIN_SURFAREA 12.566000
MAX_TRIALS 8
HEAD_TOLERANCE 0.001000
SYS_FLOW_TOL 5
LAT_FLOW_TOL 5
[EVAPORATION]
;;Evap Data Parameters
CONSTANT 0.600000
DRY_ONLY NO
[JUNCTIONS]
;;Junction Invert MaxDepth InitDepth SurDepth Aponded
10309 101.600000 9.400000 0.000000 0.000000 50
15009 111.500000 13.500000 0.000000 0.000000 50
16009 102.000000 18.000000 0.000000 0.000000 50
16109 102.800000 22.200000 0.000000 0.000000 50
80608 118.300000 16.700000 0.000000 0.000000 50
81009 128.200000 8.800000 0.000000 0.000000 50
81309 117.500000 12.500000 0.000000 0.000000 50
82309 112.300000 42.700000 0.000000 0.000000 50
[OUTFALLS]
;;Outfall Invert Type Stage Data Gated
10208 89.900000 FREE NO
[STORAGE]
;;Storage Node Invert MaxDepth InitDepth Shape Curve Name/Params Fevap Seepage
; JUNCTION DATA
80408 124.600000 13.400000 0.000000 FUNCTIONAL 1000 0 0 0 0
[CONDUITS]
;;Conduit From Node To Node Length Roughness InOffset OutOffset InitFlow MaxFlow
1030 10309 10208 500 0.016000 0.000000 0.000000 0.000000 0.000000
1570 15009 16009 500 0.015400 0.000000 0.000000 0.000000 0.000000
1600 16009 16109 500.000000 0.015000 0.000000 0.000000 0.000000 0.000000
1602 82309 16109 500 0.034000 0.000000 0.000000 0.000000 0.000000
1630 16009 10309 300.000000 0.015000 0.000000 0.000000 0.000000 0.000000
; CONDUIT DATA - base extran example or example 1
8040 80408 80608 500 0.015000 0.000000 0.000000 0.000000 0.000000
8060 80608 82309 500 0.015000 0.000000 2.200000 0.000000 0.000000
8100 81009 81309 500 0.015000 0.000000 0.000000 0.000000 0.000000
8130 81309 15009 500 0.015000 0.000000 0.000000 0.000000 0.000000
[XSECTIONS]
;;Link Shape Geom1 Geom2 Geom3 Geom4 Barrels
1030 TRIANGULAR 3 54.000000 0.000000 0.000000 1 0
1570 CIRCULAR 2 0.000000 0.000000 0.000000 1 0
1600 CIRCULAR 2 0.000000 0.000000 0.000000 1 0
1602 CIRCULAR 2 0.000000 0.000000 0.000000 1 0
1630 TRIANGULAR 3 54.000000 0.000000 0.000000 1 0
8040 CIRCULAR 2 0.000000 0.000000 0.000000 1 0
8060 CIRCULAR 2 0.000000 0.000000 0.000000 1 0
8100 CIRCULAR 2 0.000000 0.000000 0.000000 1 0
8130 CIRCULAR 2 0.000000 0.000000 0.000000 1 0
[LOSSES]
;;Link Kinlet Koutlet Kavg Flap Gate SeepRate
1030 0.000000 0.000000 0.000000 NO 0.000000
1570 0.000000 0.000000 0.000000 NO 0.000000
1600 0.000000 0.000000 0.000000 NO 0.000000
1602 0.000000 0.000000 0.000000 NO 0.000000
1630 0.000000 0.000000 0.000000 NO 0.000000
8040 0.000000 0.000000 1.000000 NO 0.000000
8060 0.000000 0.000000 0.000000 NO 0.000000
8100 0.000000 0.000000 0.000000 NO 0.000000
8130 0.000000 0.000000 0.000000 NO 0.000000
[POLLUTANTS]
;;Pollutant Units Cppt Cgw Crdii Kdecay SnowOnly Co-Pollutant Co-Frac Cdwf Cinit
Temp MG/L 0.0 0.0 0.0 0.0 NO * 0.0 29 0.0
BOD5 MG/L 0.0 0.0 0.0 0.0 NO * 0.0 25 0.0
[TREATMENT]
;;Node Pollutant Function
80408 BOD5 C = BOD5 * EXP(-1/Temp)
[INFLOWS]
;;Node Inflow Time Series Type Funits Fscale Baseline Pattern
81009 FLOW INFLOW@81009 FLOW 1.0 1.000000
82309 FLOW INFLOW@82309 FLOW 1.0 1.000000
80408 FLOW INFLOW@80408 FLOW 1.0 1.000000 1.000000
[DWF]
;;Node Parameter BaseDWF Patterns
16109 FLOW 1.000000 "" "" ""
16109 Temp 29 "" "" ""
16109 BOD5 25 "" "" ""
81009 Temp 29 "" "" ""
81009 BOD5 25 "" "" ""
80408 FLOW .1 "" ""
80408 Temp 29 "" ""
80408 BOD5 25 "" ""
[TIMESERIES]
;;Time Series Date Time Value
INFLOW@82309 01/01/1988 00:00 0.000000
INFLOW@82309 00:15 5
INFLOW@82309 03:00 5
INFLOW@82309 03:15 0.000000
INFLOW@82309 12:00 0.000000
INFLOW@80408 01/01/1988 00:00 0.000000
INFLOW@80408 00:15 5
INFLOW@80408 03:00 5
INFLOW@80408 03:15 5
INFLOW@80408 12:00 0.000000
INFLOW@80408 01/11/1988 0:00 0.000000
INFLOW@81009 01/01/1988 00:00 0.000000
INFLOW@81009 00:15 5
INFLOW@81009 03:00 5
INFLOW@81009 03:15 5
INFLOW@81009 12:00 0.000000
;;Reporting Options
INPUT NO
CONTROLS NO
SUBCATCHMENTS ALL
NODES ALL
LINKS ALL
[TAGS]
[MAP]
DIMENSIONS -1113.687 2165.261 10650.527 7792.630
Units None
[COORDINATES]
;;Node X-Coord Y-Coord
10309 389.470 2421.050
15009 4978.950 2421.050
16009 2494.740 2421.050
16109 2494.740 7536.840
80608 7463.160 7536.840
81009 9989.470 2421.050
81309 7568.420 2421.050
82309 4957.890 7536.840
10208 -578.950 4947.370
80408 10115.790 7536.840
[VERTICES]
;;Link X-Coord Y-Coord
